2 Pages12>
CCS FIXER
#1 Posted : Thursday, February 11, 2010 10:31:12 AM(UTC)
CCS FIXER
WP model LSR7233BQ1
Washer agitates great but when it comes to pumping out the water and spinning it stops and has a loud buzz sound. It doesn't matter what wash cycle it's the same thing. I checked the lid switch and it works fine, checked the pump for a clog and it was clear has a burn smell also
#2 Posted : Thursday, February 11, 2010 1:38:21 PM(UTC)
Remove the washer cabinet and check all wires at the motor harness plug. Check the motor capacitor (#26 on the diagram).
Post the results.
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSR7233BQ1 | AppliancePartsPros.com
#3 Posted : Friday, February 12, 2010 1:41:58 AM(UTC)
If you leave the washer running in spin, does the buzzing sound go away?
CCS FIXER
#4 Posted : Friday, February 12, 2010 6:35:10 AM(UTC)
CCS FIXER
NO it only buzzes when it gets to spin. No matter what cycle in agitates without any problem but as soon as it gets to spin it stops and has a buzz sound. I noticed after the second try ther was a burned smell not exactly rubber not exactly electric. I have not checked the capacitor yet but I have smelt burned capacitors before so that suggestion made sense. Will post what I find Thanks for the responses
CCS FIXER
#5 Posted : Friday, February 12, 2010 8:02:57 AM(UTC)
CCS FIXER
I just checked the capacitor ohm 9.95
#6 Posted : Friday, February 12, 2010 9:07:43 AM(UTC)
Seems like your start capacitor is bad.
CCS FIXER
#7 Posted : Friday, February 12, 2010 12:52:19 PM(UTC)
CCS FIXER
Thanks If you guys think a capacitor is the problem I'll pick one up and try it
CCS FIXER
#8 Posted : Saturday, February 20, 2010 10:01:09 AM(UTC)
CCS FIXER
The new capacitor just got here, installed and.............................
NO change anyone have any other thoughts??
#9 Posted : Saturday, February 20, 2010 11:47:09 AM(UTC)
Probably a bad timer, but without meter data, it's just a guess.
CCS FIXER
#10 Posted : Saturday, February 20, 2010 11:48:35 AM(UTC)
CCS FIXER
Give me an idea as to what and where to check and I will check it out
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
2 Pages12>
