elmagneto
#1 Posted : Thursday, April 3, 2008 5:23:01 PM(UTC)
elmagneto
Hi! I just replaced the clock assembly on this oven because the display stopped working. The problem is the new one does the same thing? Is it possible that I got a faulty clock assembly or could it be something else. Also, the oven will operate (self clean, all the buttons work) but there is no display. Thanks!!
#2 Posted : Friday, April 4, 2008 5:07:04 PM(UTC)
Most likely the new clock assembly is defective. Whoever sold it to you, has to exchange it.
Here are the break down diagrams for the Magic Chef range Model 6892VVA
Electric range clock assembly (Oven Repair (including Ranges and Cooktops))
by caroljac 10/29/2013 10:49:44 AM(UTC)
how to replace clock assembly panel (Oven Repair (including Ranges and Cooktops))
by pk48334 11/8/2011 4:08:00 AM(UTC)
Clock assembly/Control Panel it only comes in black??? (Oven Repair (including Ranges and Cooktops))
by dneiding 8/17/2010 7:17:12 AM(UTC)
clock assembly not working (Oven Repair (including Ranges and Cooktops))
by raztaz 5/13/2009 11:55:52 AM(UTC)
by raztaz 5/13/2009 11:18:10 AM(UTC)
Replace Jennair Oven clock assembly (Oven Repair (including Ranges and Cooktops))
by glenn ross 8/30/2008 9:08:35 AM(UTC)
Clock Assembly or Temp Sensor? (Oven Repair (including Ranges and Cooktops))
by Joyce 10/15/2007 5:13:37 PM(UTC)
