I just put a new motor/pump assembly in my dishwasher and now it won't drain. I'm wondering if I crossed some wires when I re-installed it. Is there a website I could go to check which wire goes where? Or is this a bad unit?
Check if you connected the wires to the drain pump?
Does it run when it comes to drain?
