Dishwasher won't drain at end of cycle...Drain lines and air gap are not plugged. The timer does rotate but the pump doesn't run through drain cycle. The pump does run for all of the wash cycles. My research would suggest either the timer motor or the solenoid. Since the timer goes through all the other cycles I would assume it works narrowing it down to a solenoid. Is there a way to verify this? Don
Originally Posted by: Gene  I unplugged the wire to the flaot assembly and put it back on and now it seems to be working.....
The basin won't drain. Is there a manual drain or something I should check? Is there a schematic that you could post or email to me so I know how to dismantle it?
Thanks much.
now it is draining fine but sometimes won't fill..
