Naomi
#1 Posted : Thursday, March 27, 2008 7:19:12 PM(UTC)
Naomi
Hello, From reading responses to my very problem I assume I need to replace the dryer belt. My dryer starts/heats but will not spin. Is this an easy repair? I have never repaired an appliance before. Thanks
fixtec90
#2 Posted : Friday, March 28, 2008 5:25:34 AM(UTC)
fixtec90
Piece of cake. Unplug dryer. Remove two screws located at lint filter housing. use putty knife to press clips under top, 1 at each side of the front and lift top back. Remove 2 bolts (5/16), 1 on either side. pivot front down and lift off bottom tabs. If careful you can remove front and pivot out of your way w/o removing wires for door switch. If the idler pulley has fallen it fits into 2 slots in front fo the motor. Slide new belt over the drum with the ribs facing down. make sure the belt isn't twisted. Hold idler pulley. pinch belt and pull under the idler pulley wheel. put the piece of the belt you are still holding around the motor pulley. If done correctly the ribbed side of the belt will be wrapped around the motor pulley. Once the belt is on turn the drum by hand a couple times to make sure the belt won't pop off once back together. Put everything back together and start your laundry. Don't forget to give yourself a pat on the back for a job well done. Good luck.
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
SG1000 dryer belt replacement (Dryer Repair)
by Guest 6/28/2021 3:29:53 PM(UTC)
Dryer Belt Whirlpool lew0050pq2 - help (Dryer Repair)
by otj287@gmail.com 3/25/2019 8:43:14 AM(UTC)
GE Dryer Belt keeps breaking (Dryer Repair)
by missle 9/13/2017 7:02:48 AM(UTC)
Dryer Belt Restrainer Melts (Dryer Repair)
by notamechanic 8/15/2015 10:09:07 AM(UTC)
Trying to Replace My Danby Dryer Belt (Dryer Repair)
by PDR51 8/6/2015 8:32:22 AM(UTC)
Dryer belt (Dryer Repair)
by MintJulep 4/27/2015 5:44:33 AM(UTC)
Maytag Dryer belt routing (Dryer Repair)
by Electechab 2/5/2015 2:16:47 PM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Please help me change my dryer belt (Dryer Repair)
by jayathorn 9/10/2014 1:47:01 PM(UTC)
Can't find a replacement dryer belt! (Dryer Repair)
by Pat the Rat 7/22/2014 3:53:40 PM(UTC)
Breaking Dryer belts (Dryer Repair)
by DCG65 7/27/2013 11:56:52 AM(UTC)
Dryer Belt Tensioning/Placement Issue (Dryer Repair)
by formula 1/2/2013 5:07:21 PM(UTC)
dryer belt installation, no pulley (Dryer Repair)
by flamingo 12/12/2012 7:19:25 AM(UTC)
Putting on dryer belt (Dryer Repair)
by Martin Miller 11/2/2012 5:50:02 PM(UTC)
