uechido
#1 Posted : Friday, January 29, 2010 8:17:29 PM(UTC)
uechido
Gene if you are out there??
Not sure what repair parts to purchase. )ver the last 2 weeks the lights on the control panel have been failing. It started on the right side - (wash type select) then moved to the center (start). now when start is pressed nothing happens.
Is there a way to repair the switch/light assy or will i need to replace the control panel? the panel is black and the s# starts with 32.
Thanks for the help,
uechido
#2 Posted : Saturday, January 30, 2010 1:19:16 PM(UTC)
Perform the manual function test as described in the Tech sheet (page 5) and post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDBTT50AWS Dishwasher - Undercounter | AppliancePartsPros.com
uechido
#3 Posted : Saturday, January 30, 2010 4:13:31 PM(UTC)
uechido
Thanks Gene:
Tried to initiate the test sequence 3 times but it would not work. The heated dry LED alternated on/off each time it was depress. That is all that happened.
Uechido
#4 Posted : Saturday, January 30, 2010 4:19:37 PM(UTC)
Sounds like the problem is a bad control panel, but there is a small chance for the control board to be bad as well.
- The control panel Part number: AP4364227
uechido
#5 Posted : Saturday, January 30, 2010 5:09:52 PM(UTC)
uechido
Thanks Gene; I'll get it on order. appreciate all the help!
uechido
#6 Posted : Tuesday, February 2, 2010 3:55:50 PM(UTC)
uechido
  • Ordered the part Saturday
  • Arrived in 2 days
  • installed in 10 minutes
  • washing dishes in 15 minutes
  • Saved $$$$$
  • Wife happy - Ok not sure about the happy part!
thanks again
Uechido
#7 Posted : Thursday, February 4, 2010 11:00:44 AM(UTC)
You are welcome. I'm glad you were able to fix it.
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by Strum310 11/15/2015 5:57:23 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
