Gene if you are out there??
Not sure what repair parts to purchase. )ver the last 2 weeks the lights on the control panel have been failing. It started on the right side - (wash type select) then moved to the center (start). now when start is pressed nothing happens.
Is there a way to repair the switch/light assy or will i need to replace the control panel? the panel is black and the s# starts with 32.
Thanks for the help,
uechido
Thanks Gene:
Tried to initiate the test sequence 3 times but it would not work. The heated dry LED alternated on/off each time it was depress. That is all that happened.
Uechido
Sounds like the problem is a bad control panel, but there is a small chance for the control board to be bad as well. - The control panel Part number: AP4364227
Thanks Gene; I'll get it on order. appreciate all the help!
- Ordered the part Saturday
- Arrived in 2 days
- installed in 10 minutes
- washing dishes in 15 minutes
- Saved $$$$$
- Wife happy - Ok not sure about the happy part!
thanks again Uechido
You are welcome. I'm glad you were able to fix it.
