Please help to fix the door-front panel, where's the placement of spring handle; handle door; and lever door. I tried to do it myself but it's not right. Thanks a lot
Thank you very much and appreciated. I knew is on page 20, number 4- 5. Unfortunately, i got it from justanswer.com, but i have to pay. sucks! But still. I'm having a problem with the spring handle, handle door and lever door i don't know the proper placement. i keep trying but it's not right. When i assemble and tested, there's a message dL, means door lock, not closed tightly. Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
Well, sorry that did not give a complete answer, and without one of the machines in front of me I really cannot tell you what your problem is.
I may have on in the shop but will not be in there until Tuesday at the earliest, and if so I will try to look at it and take some pics.
Maybe someone else can chime in here to help.
well, thank you in advance. i hope you can help as early. I keep searching the answer of my problem. Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Well, sorry that did not give a complete answer, and without one of the machines in front of me I really cannot tell you what your problem is.
Originally Posted by: doran620 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) well, thank you in advance. i hope you can help as early. I keep searching the answer of my problem.
sidfink43, I'm still hoping that you can still help me. Thanks. :D :) :) Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Well, sorry that did not give a complete answer, and without one of the machines in front of me I really cannot tell you what your problem is.
I do not have one in the shop, so I can only suggest you contact Whirlpool and see if they can provide you with a diagram.
