doran620
#1 Posted : Friday, January 29, 2010 7:29:45 PM(UTC)
doran620
Please help to fix the door-front panel, where's the placement of spring handle; handle door; and lever door. I tried to do it myself but it's not right. Thanks a lot
sidfink43
#2 Posted : Sunday, January 31, 2010 8:43:51 AM(UTC)
sidfink43
See if this service manual doesn't show you where things go.
http://www.servicematters.com/m...ibrary/docs/16023430.pdf
doran620
#3 Posted : Sunday, January 31, 2010 3:00:49 PM(UTC)
doran620
Thank you very much and appreciated. I knew is on page 20, number 4- 5.
Unfortunately, i got it from justanswer.com, but i have to pay. sucks! But still. I'm having a problem with the spring handle, handle door and lever door i don't know the proper placement. i keep trying but it's not right. When i assemble and tested, there's a message dL, means door lock, not closed tightly. UserPostedImage UserPostedImage
sidfink43
#4 Posted : Sunday, January 31, 2010 4:00:27 PM(UTC)
sidfink43
Well, sorry that did not give a complete answer, and without one of the machines in front of me I really cannot tell you what your problem is.
I may have on in the shop but will not be in there until Tuesday at the earliest, and if so I will try to look at it and take some pics.
Maybe someone else can chime in here to help.
doran620
#5 Posted : Sunday, January 31, 2010 4:11:56 PM(UTC)
doran620
well, thank you in advance. i hope you can help as early. I keep searching the answer of my problem.
doran620
#6 Posted : Monday, February 1, 2010 5:29:32 PM(UTC)
doran620
UserPostedImage
doran620
#7 Posted : Monday, February 1, 2010 7:32:36 PM(UTC)
doran620
sidfink43, I'm still hoping that you can still help me. Thanks. :D :) :)
sidfink43
#8 Posted : Tuesday, February 2, 2010 6:53:04 AM(UTC)
sidfink43
I do not have one in the shop, so I can only suggest you contact Whirlpool and see if they can provide you with a diagram.
