luirod563
#1 Posted : Saturday, August 25, 2007 4:32:09 PM(UTC)
luirod563
I would like to know if this problem can be fix and how.The washing machine stops after it finishes the washing cycle.It doesn't start draining the water.
Thank you for u help.
#2 Posted : Sunday, August 26, 2007 10:18:47 AM(UTC)
Hi luirod563
The first thing I would check is the lid switch. If the lid is open or the switch is broken the washer would not drain and/or spin.
- New lid switch and step by step instructions on how to replace the lid switch: Part number: AP3100003
- Here is the break down diagrams for the Whirlpool washer Model LSR5132HQ0
Good luck.
#3 Posted : Sunday, August 26, 2007 10:22:17 AM(UTC)
Hi luirod563
The first thing I would check is the lid switch. If the lid is open or the swithch is broken the washer would not drain and/or spin.
- The part number for the lid switch is AP3100003
Good luck.
jesse
#4 Posted : Friday, October 12, 2007 2:58:22 AM(UTC)
jesse
my washer had the same problem
it was the lid switch.
it was cracked in half.
#5 Posted : Friday, October 12, 2007 7:38:17 AM(UTC)
Good job, Jesse
