luirod563
#1 Posted : 18 years ago
luirod563
I would like to know if this problem can be fix and how.The washing machine stops after it finishes the washing cycle.It doesn't start draining the water.
Thank you for u help.
#2 Posted : 18 years ago
Hi luirod563
The first thing I would check is the lid switch. If the lid is open or the switch is broken the washer would not drain and/or spin.
- New lid switch and step by step instructions on how to replace the lid switch: Part number: AP3100003
- Here is the break down diagrams for the Whirlpool washer Model LSR5132HQ0
Good luck.
#3 Posted : 18 years ago
Hi luirod563
The first thing I would check is the lid switch. If the lid is open or the swithch is broken the washer would not drain and/or spin.
- The part number for the lid switch is AP3100003
Good luck.
jesse
#4 Posted : 17 years ago
jesse
my washer had the same problem
it was the lid switch.
it was cracked in half.
#5 Posted : 17 years ago
Good job, Jesse
