Bnogu
#1 Posted : Monday, March 24, 2008 11:56:18 AM(UTC)
Bnogu
I have a gas dryer and it was working fine. We smelled a little gas and had the gas company come by. They had me change the gas hose going from the dryer to the gas pipe with a yellow hose instead of the grey hose that had came with the dryer.
From that point on the dryer will ignite and the flames will come on but then after a little bit the flames shut off and there is no heat in the dryer to dry the clothes
We then have to run about 3 to 4 cycles in order for the clothes to be dry. This is time consuming and costly because of the energy that it is using.
What should I do to get the dryer working?
I have replace the exhaust hose going from the dryer to the ceiling/outside already.
#2 Posted : Tuesday, March 25, 2008 9:33:43 AM(UTC)
Most likely the problem with your dryer is a bad gas valve coils.
- The part number for the kit of coils is AP2150379
For any further questions we need the complete model number of the dryer.
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
Belarus Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
