dfbaxte
#1 Posted : Monday, March 24, 2008 6:04:32 AM(UTC)
dfbaxte
my oven started with codes of f7 i could shut off the power and the oven would work properly for about a hour and then code again. it now will not code f7 but will work properly at the temp. of 290 degrees or below. if you enter a temp above 290 degrees i will get only err no codes. i was told by a repair man that i had a sticking key pad that was causing the issue. what i do not remember is what part he said i needed to fix the problem and they has since gone out of business. could you please advise me in what part i would need to order to fix my issues.
thanks dan
#2 Posted : Monday, March 24, 2008 5:22:03 PM(UTC)
thanks dan
Hi Dan,
These two problems are absolutely different.
In order to fix the temperature problem you have to change the temperature selections from Celsius to Fahrenheit.
Press and hold the Bake and Broil pads on the upper oven control at the same time for 3 seconds or until the display shows "SF".
Press the Broil pad. The display will show "C".
Press the Broil pad again. The display will show "F".
Press the Start pad.
In order to fix the "F7" error code, the control panel has to be replaced.
- The part number for the control panel is AP2029597
Here are the break down diagrams for the GE oven Model JKP56AA1AA
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
Kennmore Elite Top Load Washer - MHK62125813 - Error Codes (Washer Repair)
by maxxam864 1/4/2023 12:11:00 PM(UTC)
Error Codes on lg dishwasher LDF5545st (Dishwasher Repair)
by Guest 7/25/2022 10:57:38 AM(UTC)
GE GTW330ASK1WW odd behavior and multiple error codes for lid lock (Washer Repair)
by petermbooth 6/3/2022 5:11:39 PM(UTC)
Frigidaire gallery error codes (Oven Repair (including Ranges and Cooktops))
by Guest 5/9/2021 9:55:31 AM(UTC)
Does anyone know how to clear error codes on Bosch Washer (Washer Repair)
by bmoney37 6/12/2020 9:35:37 PM(UTC)
Whirlpool Duet Steam Error Codes (Dryer Repair)
by etamunupe 3/28/2020 5:09:00 AM(UTC)
front load washer error codes (Washer Repair)
by scully61 11/19/2018 5:44:51 AM(UTC)
Jenn-air Gas Range Error codes (Oven Repair (including Ranges and Cooktops))
by uncledave11 3/29/2018 11:48:39 AM(UTC)
No error codes (Oven Repair (including Ranges and Cooktops))
by docnpat 2/16/2018 8:08:11 PM(UTC)
Kitchen aid not cleaning dishes have error codes (Dishwasher Repair)
by Randall1803 11/13/2016 6:55:35 PM(UTC)
Help with Maytag Washing Machine Error Codes (Washer Repair)
by Gjohnlue 7/8/2016 3:58:06 PM(UTC)
