cocodon
#1 Posted : Wednesday, January 27, 2010 6:26:25 AM(UTC)
cocodon
Dishwasher only works in Light Wash mode.....other modes will not work and their led's do not light.
#2 Posted : Thursday, January 28, 2010 3:30:10 AM(UTC)
A model number may help others help you.
Try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner II DU1145 (Dishwasher Repair)
by Guest 3/25/2021 6:39:10 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner II Model DU1055XTVQ8 (Dishwasher Repair)
by mgandhd 4/29/2020 9:16:12 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet Partner II (Dishwasher Repair)
by dresstheman 12/30/2017 5:17:12 PM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool quiet partner ii won't start (Dishwasher Repair)
by Mac m 1/6/2015 5:53:21 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
