SteenHensley
#1 Posted : 17 years ago
SteenHensley
I recently tripped on my dishwasher door and fell on it. The door now looks as though it has bent a little and has pried up from the gasket. It still works okay, but leaks a little near the corner of the door and it's noisier. Any suggestions?:(
Rare Wind
#2 Posted : 17 years ago
Rare Wind
My daughter just fell on our brand new (around 2 months old) Frigidaire. Now the door sags when you open it, instead of stopping so the bottom rack is flat when you pull it out. It is model FDBB4365FC0 . When I go on the website for warranty info, it is all Canadian provinces, nothing for U.S.
The door doesn't leak at all and the washer works fine. When I look at the door hinge, it is a cord attached to a spring and I don't see anything obviously bent, or anything to stop its travel. I would like to find the service drawing so I can fix it but I cant find anything online. I think electrolux services frigidaire products in the US. If any one knows what part actually stops the door's travel when you open it so that the door stays level and flat, PLEASE let me know! Thank You !
:confused:
SteenHensley
#3 Posted : 17 years ago
SteenHensley
I found this website for Frigidaire manuals. When you put in your model number and then click on the installation manual it will give you a pdf file for removing and replacing the door. (At least it did for mine.) I think that's what I'll try, just taking it off and trying to straighten it and then reinstalling.
:oSteenHensley
SteenHensley
#4 Posted : 17 years ago
SteenHensley
Oops! Forgot to give you the website!
http://www.frigidaire.com/support/manuals.asp
:o
Frigidaire Door Lock ? I think (Washer Repair)
by schatz78240 12 years ago
frigidaire door won't close properly (Refrigerator & Freezer Repair)
by falls 13 years ago
frigidaire door lock (Washer Repair)
by unit1018 13 years ago
Frigidaire door hinges loose and door sags (Microwave Repair)
by mwvfix 13 years ago
Frigidaire door popping when opening. (Refrigerator & Freezer Repair)
by Conlanj 14 years ago
Frigidaire Door Heavy (Dishwasher Repair)
by FixingIt 14 years ago
Frigidaire door part (Refrigerator & Freezer Repair)
by rharrity 14 years ago
Frigidaire Door Lock and F9 error code (Oven Repair (including Ranges and Cooktops))
by chispaluz 15 years ago
Frigidaire door lock assembly (Washer Repair)
by frustratedmomma 15 years ago
frigidaire door lock repair (Washer Repair)
by docjlee 16 years ago
frigidaire door switch (Washer Repair)
by donfoulk 16 years ago
Frigidaire Door Seal (Dishwasher Repair)
by steve-r 16 years ago
How do I get the front panel back on Frigidaire door? (Dishwasher Repair)
by Daddo 17 years ago
Frigidaire door spring installation (Dishwasher Repair)
by aipc29 17 years ago
Frigidaire Door Lock asemble repair (Washer Repair)
by heyingh 17 years ago
