ok, Im new at all this appliance fixing, but here is what is going on.
When I cycle the washer on, the door latch (clicks), its indicator light comes on... but then 2 to 3 second later the lights go off and unlatches, wash cycle never starts. Im assuming due to the door not being latched.
How can I determine if its a latch assembly? or a computer issue?
Note: about 6 months ago we had to replace the striker on the door.
Please help.
Groups: APP Team
Hi. Check the resistance of the door lock's wax motor and if it's different than 1500ohm - replace it Part number: 131763202
