jschee
#1 Posted : Wednesday, March 19, 2008 3:21:12 PM(UTC)
jschee
I replaced the control unit on the stove a year ago - clock set button & oven start didn't work. Everything appeared to work fine after I replace it, but I didn't check to see if Oven Clean feature worked. We seldom use the oven & normally don't get it dirty. Now it is dirty and when we turn on self-cleaning we get a "door" error message. I unplugged & pulled back off and get continuity on oven lock switch at the control unit when I lock for cleaning and open when self-cleaning lock is not engaged. Is there anything other than the control unit that can cause this failure. Oven works fine otherwise - both elements! Just can't clean it!
#2 Posted : Wednesday, March 19, 2008 5:09:20 PM(UTC)
What error code exactly was shown on the display?
jschee
#3 Posted : Wednesday, March 19, 2008 5:54:12 PM(UTC)
jschee
It was not a numerical error code. It was in plain english!!! DOOR
#4 Posted : Thursday, March 20, 2008 3:44:35 PM(UTC)
Check the wires from the switch to the control board and the plug at the control board.
If there is nothing wrong then the problem is a bad control board.
jschee
#5 Posted : Thursday, March 20, 2008 4:16:51 PM(UTC)
jschee
Thanks, When I checked the switch I checked it at the control panel including wiring to switch, so guess its control panel. I figured it had to be, I just didn't want to spend a couple hundred for it and have it not fix the problem.
Guest (5)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Strange Whirlpool Electric Range Problem and Quandry (Oven Repair (including Ranges and Cooktops))
by TheDoctorsCompanion 1/6/2015 6:26:01 PM(UTC)
Whirlpool electric range oven (Oven Repair (including Ranges and Cooktops))
by king1 6/22/2014 5:11:19 AM(UTC)
Whirlpool Electric Range LR cooktop not working (Oven Repair (including Ranges and Cooktops))
by binw022@yahoo.com 2/18/2013 5:53:12 AM(UTC)
Whirlpool Electric Range (Oven Repair (including Ranges and Cooktops))
by JWhiteOH@aol.com 3/14/2012 6:00:15 PM(UTC)
Replaced Control Panel on Whirlpool Electric Range but there is nothing (Oven Repair (including Ranges and Cooktops))
by lheidema 6/5/2011 7:20:00 PM(UTC)
Whirlpool Electric Range Not Heating Up (Oven Repair (including Ranges and Cooktops))
by Mikecass 5/2/2011 12:36:25 PM(UTC)
Whirlpool Electric Range doesn't work (Oven Repair (including Ranges and Cooktops))
by Holmes59 3/17/2011 8:17:28 AM(UTC)
Whirlpool electric range - Oven (Bake light) does not stay ON (Oven Repair (including Ranges and Cooktops))
by dieselgg 11/16/2008 11:23:04 AM(UTC)
