Mik
#1 Posted : Monday, March 17, 2008 2:19:54 PM(UTC)
Mik
Gentlemen,
Recently, I discovered that my freezer (20.6 cu. ft - upright) stopped working (partially thawed meat). I advanced the temp control knob from 4 to 6 and heard the compressor kick on. I then immediately dialed the temp control wheel back to 4.
The freezer continued to work for 2 additional days before it went back to being broke (partially frozen water bottles).
I realize the reason may be just about anything but is there anything I can trouble shoot to locate the culprit. I live in a remote area and service technicians are hard to locate.
Thx!
Mik
#2 Posted : Tuesday, March 18, 2008 2:00:32 PM(UTC)
Hi Mik,
In order to provide most accurate advise we need the complete model number of the unit.
Mik
#3 Posted : Tuesday, March 18, 2008 2:12:06 PM(UTC)
Mik
Gene,
Thanks for your email. WOW, this reply system seems cumbersome. I'm not sure if you'll get this nor am I sure if you will know whom it is from. Anyway, you asked for the model number of my 8 yo Kenmore freezer which is 253.9280213, Serial No. WB02122482. My issue is thus. Upon discovery that my meat was partially thawed in the upright, 20.3 cu. ft. freezer, I turned the temp control dial from the 4 position to the 6 position. Immediately the compressor kicked on so I dialed the temp. control back to No. 4. Things chugged along very well for approximately 2 days before the freezer gave up the ghost entirely. I'm trying to trouble shoot the problem as getting a tech. out to my remote location is challenging at worst. If there are similar folks reporting the same problem and there is a common remedy, I'd love to learn it.
Thank-you Gene,
Mik
#4 Posted : Tuesday, March 18, 2008 2:32:37 PM(UTC)
Mik,
The first thing I would do is bypass the temperature control.
If the compressor will start then the problem is a bad temperature control.
- The part number for the temperature control is AP2113445
Mik
#5 Posted : Tuesday, March 18, 2008 2:39:18 PM(UTC)
Mik
Now ,why didn't I think of that - duh!
Guess that's why u get the big bucks!!!
Thx. Cross your fingers that's the issue.
I'll do what you suggest tonight and will let ya know the results either positive or negative.
Thanks again!
Mik
#6 Posted : Thursday, March 20, 2008 1:01:59 PM(UTC)
Mik
Gene,
By-passed the temp control and compressor started. Therefore, I ordered the part you referenced via our last communication. Thx again.
Does it harm the freezer to sit the 4 days until the part arrives? Otherwise, I'll by-pass the switch and let the freezer run for a bit.
Mik
#7 Posted : Thursday, March 20, 2008 2:06:35 PM(UTC)
Mik,
Keep it off and let me know how it'll go.
Mik
#8 Posted : Monday, March 31, 2008 12:44:51 PM(UTC)
Mik
Gene,
New switch works. Freezer has been working fine for days now. I believe I got it licked thanks to your advice. thx again.
However, I forgot how the power leads hook up so i took a guess and figured it is ac and doesn't matter??? If one looks from the dial side I connected the blue lead to the left terminal.
Mik
#9 Posted : Monday, March 31, 2008 12:58:53 PM(UTC)
Hi Mik,
I'm glad you were able to fix it. Do not worry about wires - it does not matter.
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
Kenmore upright freezer cycle of warming up then chilling below zero. (Refrigerator & Freezer Repair)
by bigcheesehead 9/27/2023 9:05:10 AM(UTC)
Kenmore upright freezer model 253.280528015 keeps tripping ground fault (Refrigerator & Freezer Repair)
by Guest 8/24/2023 11:17:55 AM(UTC)
Frigidaire upright freezer model FFFH17F2QWA (Refrigerator & Freezer Repair)
by Guest 4/6/2023 11:29:17 AM(UTC)
Frigidaire Upright Freezer Misbehaving (Refrigerator & Freezer Repair)
by sun_lover 3/23/2023 12:32:46 PM(UTC)
Green Light at bottom front of Frigidaire upright freezer (Refrigerator & Freezer Repair)
by Guest 9/7/2022 10:43:50 PM(UTC)
Sears cold spot upright freezer Model #2423 (Refrigerator & Freezer Repair)
by Guest 9/1/2021 6:06:27 AM(UTC)
Whirlpool Upright freezer throwing itself into defrost mode (Refrigerator & Freezer Repair)
by Wayne O 7/26/2021 10:25:04 AM(UTC)
Frigidaire upright freezer runs for several hours then shuts off (Refrigerator & Freezer Repair)
by Guest 7/21/2021 11:32:11 AM(UTC)
Frigidaire Upright Freezer (FFH17F7H) showing wrong temperature (Refrigerator & Freezer Repair)
by Guest 7/21/2021 6:21:52 AM(UTC)
Frost/ice on only one upright freezer shelf (Refrigerator & Freezer Repair)
by whitedavidp1 4/28/2021 12:33:57 PM(UTC)
Defrost cycle-Fridgidaire mod FPUH19D7LF1 upright freezer (Dishwasher Repair)
by samv 6/23/2020 1:02:25 PM(UTC)
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 9/30/2019 7:09:57 AM(UTC)
GE 20DADRWH Upright Freezer (Refrigerator & Freezer Repair)
by Robo1027 3/3/2019 3:47:26 PM(UTC)
