Recently my dryer started squeeking. It started off just in the beginning but now it seems to last longer and getting louder. I have a Maytag dryer: Model# SDE515DAYW I haven't taken the dryer apart yet but from what I have read I think it must be the following parts. Will this probably take care of this squeeking problem?
Assy, roller braket: #AP4048635 Cylinder roller: #AP4046756 Thrustwasher: #AP4032235 (2 needed) Ring-RETA: #AP4032235 Screw,10-16x 1/2: #AP3085356
This would be for the one roller, I assume I would need two sets of these to ensure both rollers are replaced at the same time.
I noticed from previous posts but with different models that the rear rollers and idler pulley were the recommended replacement parts. However I don't seem to see these parts for my model.
Thanks,
Jonathan
The idler wheel or more common the two rear rollers would be my guess.
If you take it apart and spin these parts by hand you can often tell just what one is making the noise.
