I need to replace my dryer drum glide how to do it? thank you
Groups: APP Team
Hi, Walter. If you are sure that the reason for squeaking the glides, then do this: - remove the top and front. -you will see inside the front edge of the drum two glides. if they are bad -replace them by simply releasing tabs. - check the felt seal. The glide Part number: AP2107932
