How do you get into the "guts" of the dryer to see what might be squeeking? What is usually the problem if it is a continual squeek?
Originally Posted by: jimgordey01 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How do you get into the "guts" of the dryer to see what might be squeeking? What is usually the problem if it is a continual squeek? My Maytag has been shrieking for a week. Just ordered a bearing kit and roller kit. Hope I got all the parts. Now to your question. Open the dryer door. There should be 4 screw along the inside lip of door opening. The front panel should be held onto the caibinet by clips secured to the front shroud. to remove the front panel grasp the goal posts of the front panel 3/4 of the way down and pull front panel away from dryer.
There are some good youtube video's on maytag dryer ideler pulley repair that show you how to take apart a dryer
