BOBSTOUFUS
#1 Posted : Monday, January 18, 2010 10:22:25 AM(UTC)
BOBSTOUFUS
Refrigerator is not getting cold enough and there is no air flow from the top damper. Freezer compartment seems to be without issue.
What is the best way to troublshoot from this point and what is the easiest resolution.
RW Stoufus
bobstoufus@gmail.com
#2 Posted : Tuesday, January 19, 2010 2:44:31 AM(UTC)
I would remove the back freezer panel and check for a totally frozen evaporator.
Toddinsd
#3 Posted : Wednesday, January 20, 2010 10:00:10 AM(UTC)
Toddinsd
Pulled panel off back of freezer in order for the frig to get cold air fan that has to transfer it uo Seen working intermittently before this one was stuck,,,
One of the sheet metal screws that attached it to braket had sheered off. Once It was re-attached shaded pole motor was back running and easy fix,,,, I guess this is why they make differn't grade fasteners,,
#4 Posted : Wednesday, January 20, 2010 2:07:09 PM(UTC)
Good job, I like tinnerman nuts.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
front load amana door misalign (Washer Repair)
by wilsonjiaho 5/17/2024 1:02:16 PM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
Amana fridge warm, freezer cold (Refrigerator & Freezer Repair)
by agdodge4x4 12/25/2023 6:22:47 PM(UTC)
NTW4516FW3 Amana Top Loader Washer (Washer Repair)
by KMags 11/28/2023 4:52:44 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Amana fridge SX26VE door seals, hens teeth? (Refrigerator & Freezer Repair)
by Guest 8/31/2023 10:58:17 AM(UTC)
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
