johnl
#1 Posted : Monday, March 17, 2008 12:58:15 PM(UTC)
johnl
I have an old Kenmore 220V elec dryer. It stopped dead, will not start. Breakers are OK. Door switch is OK. Apparently has NO thermal fuse that I can find. I believe it is either the motor or timer. Unfortunately timer is no longer available. I was wondering what anyone would recommend as far as testing the timer, and motor. Motor is common, still available (common replacement is). Also, can anyone date it?
John
johnl
#2 Posted : Tuesday, March 18, 2008 11:32:58 AM(UTC)
johnl
Some progress....
Bought a sears kenmore dryer repair handbook. Doesn't cover this exact timer set-up but some of the general continuity checks seemed to apply. On mine the push to start switch is built into timer, on one shaft. At terminals, between red and yellow, open with timer in off position. closed in run position. TPS terminal to either red or yellow open, pressing start switch, TPS to either red or yellow closed. Seems to be OK?
Looks like either motor or something else. Will Ohm motor next.
I would like to find the correct wiring diagram for this model, and still trying to date it. No thermal fuse means probably a little older.
johnl
#3 Posted : Friday, March 28, 2008 1:31:22 AM(UTC)
johnl
Checked the motor windings, 2-5 ohms each, which is good. Checked the power cord, was burned, corroded at terminal block. Replaced it. Test ran it with old motor, worked fine. Put back together, running good.
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Jenn Air SVD48600P Downdraft not working, need troubleshooting help (Oven Repair (including Ranges and Cooktops))
by Don Tumas 1/5/2022 5:53:18 PM(UTC)
Troubleshooting help before I order parts (Washer Repair)
by GoogleAndroid 3/16/2017 8:40:29 PM(UTC)
Troubleshooting Help: Heats at first, then just cold air..? (Dryer Repair)
by KatieWisc 2/16/2017 12:56:56 PM(UTC)
troubleshooting help (Dryer Repair)
by claggett63 11/23/2014 7:53:58 AM(UTC)
Need Troubleshooting Help (Refrigerator & Freezer Repair)
by moodymail 4/11/2013 7:39:15 PM(UTC)
Troubleshooting help (Washer Repair)
by AVguy 3/2/2013 8:16:43 AM(UTC)
Whirlpool RBS245PDB11 Troubleshooting help (Oven Repair (including Ranges and Cooktops))
by db336 2/17/2012 9:17:29 PM(UTC)
Ice dispenser - troubleshooting help! (Refrigerator & Freezer Repair)
by supercharge 9/4/2011 2:14:38 PM(UTC)
Dryer Will Not Start - Need troubleshooting help (Dryer Repair)
by quickdraw841 4/2/2011 8:26:18 AM(UTC)
Troubleshooting Help Needed (Oven Repair (including Ranges and Cooktops))
by bobar 11/10/2007 9:40:33 AM(UTC)
