RitaH
#1 Posted : Tuesday, January 19, 2010 1:04:06 PM(UTC)
RitaH
Dishwasher will not drain after last rinse cycle, all other cycles drain. Any ideas on what could be wrong?
#2 Posted : Wednesday, January 20, 2010 2:39:26 AM(UTC)
Replacement parts for GSD4260JSS models | AppliancePartsPros.com
You have to do more trouble shooting.
Does motor run during final drain?
Does the wash/drain solenoid actuate during final drain?
Does it drain any water at all or none?
When it drains during the cycle does it empty the unit all the way? Note these pumps usually leave a quarter inch or so of water in the bottom of the tub.
RitaH
#3 Posted : Wednesday, January 20, 2010 12:13:58 PM(UTC)
RitaH
Yes, the motor runs during final drain cycle. During final rinse, all I hear is water swishing around and clicking from the knob. Wash/drain solenoid engages on all drain cycles, except when it's supposed to engage after the final rinse. No water drains on final rinse cycle, drains completely on all others. There is alot more than a quarter inch after that final rinse cycle.
#4 Posted : Wednesday, January 20, 2010 1:14:57 PM(UTC)
As long as your option buttons work as they should, my guess would be that the timer is the cause.
The motor, solenoid etc. all are OK so all that is left is the timer.
RitaH
#5 Posted : Thursday, January 21, 2010 8:03:18 PM(UTC)
RitaH
Do you carry the replacement part?
Migeguy
#6 Posted : Friday, January 22, 2010 6:32:06 AM(UTC)
Migeguy
problem is most likely the piston in te rear filter.in the back of the unit is a filter held in place by 4 screws.remove filter and unscrew the piston that is in the middle.it has a silicone stopper in the piston that should close the hole when pushed in.if it is worn down you will need to replace.
#7 Posted : Wednesday, January 27, 2010 12:56:36 AM(UTC)
Open the parts link, timer is Item 853 in Section 1.
Replacement parts for General Electric GSD4260J00SS Dishwasher | AppliancePartsPros.com
Sorry for not getting back to you sooner but got stuck at the lake due to a storm.
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
