roc99
#1 Posted : Saturday, March 15, 2008 5:03:51 PM(UTC)
roc99
Hello. My dryer will not start but the timer is ticking. The inside light is not operating and it used to work fine too. The door switch tests godd. Any suggestions would be appreciated. Thanks.
#2 Posted : Sunday, March 16, 2008 2:20:58 AM(UTC)
I would pull the dryer apart and check the thermal fuse on the blower housing, a white plastic disk about 1 inch diameter.
roc99
#3 Posted : Monday, March 17, 2008 6:31:04 PM(UTC)
roc99
I have found what appears to be a thermostat control (referring to the schematic) at the blower housing cover. It has 4 wires attatched. There are no other discs or wires there so did you mean this item or is the thermal fuse located elsewhere.
#4 Posted : Tuesday, March 18, 2008 2:45:19 AM(UTC)
On this dryer, the thermal fuse is not on the blower housing, so I don't know where it is. It is wired in between the door switch and ground. That should help you find it.
abbie
#5 Posted : Tuesday, March 18, 2008 6:08:49 AM(UTC)
abbie
I would check first,to see if there is a blown fuse or open breaker there might be only 110 volts going to the dryer.Check your fuse panel there should be 240 volts going to the dryer. It sounds like one off the two fuses are blown.
roc99
#6 Posted : Tuesday, March 18, 2008 6:08:26 PM(UTC)
roc99
I found the thermal fuse in the area of the heating element housing. Sure enough it had infinite resistance so I replaced it. I also replaced the high limit thermostat as a precaution to not blowing the fuse again, according to the enclosed instruction sheet. The passages were full of old packed lint so the dryer is clean and working great. Thanks very much for the diagnosis as it saved me buying a new one.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
