I have a Bosch dishwasher Integra model: SHU9955UC/14. Nothing happens when any of the buttons are pushed. I pulled the front panel off and it’s getting 120 volts to the switch. It’s also getting power to the control module when the power button is pressed. I’ve replaced the 20 amp home breaker and even bought a new control module from a local shop. (150.00 bucks) I’m running out of ideas. Do you have some advice? Please help. Is it possible that I bought a bad control module?
does this model have a wiring harness behind front door panel on left side near botton covered with black vinyl sheilding .and a clear plastic covering over that ,sometimes wiring in harness can be burned .do you smell any burn smell there?
