goosebike77
#1 Posted : Saturday, March 15, 2008 9:35:31 AM(UTC)
goosebike77
I have a Bosch dishwasher Integra model: SHU9955UC/14. Nothing happens when any of the buttons are pushed. I pulled the front panel off and it’s getting 120 volts to the switch. It’s also getting power to the control module when the power button is pressed. I’ve replaced the 20 amp home breaker and even bought a new control module from a local shop. (150.00 bucks) I’m running out of ideas. Do you have some advice? Please help.
Is it possible that I bought a bad control module?
#2 Posted : Saturday, March 15, 2008 9:13:20 PM(UTC)
Did you check the door switch (#3 on the fascia panel breakdown diagram) for continuity?
With the fascia panel removed check if the door switch is engaged properly.
Here are the break down diagrams for the Bosch dishwasher Model SHU9955 UC/12 (FD 8105 -)
misterfixall
#3 Posted : Sunday, March 16, 2008 4:13:32 PM(UTC)
misterfixall
does this model have a wiring harness behind front door panel on left side near botton covered with black vinyl sheilding .and a clear plastic covering over that ,sometimes wiring in harness can be burned .do you smell any burn smell there?
Dishwasher control panel lights come on, but nothing happens (Dishwasher Repair)
by PaulTernstrom 9/7/2020 4:28:55 PM(UTC)
The timer continues ticking but nothing happens (Washer Repair)
by yqjcyxx1956 5/21/2014 5:10:15 AM(UTC)
Water dispenser is not working - when lever is pressed, nothing happens. (Refrigerator & Freezer Repair)
by jwhite01 12/4/2012 11:19:20 AM(UTC)
KitchenAid-Push Start nothing happens (Dishwasher Repair)
by DTM-69 4/16/2012 4:11:03 PM(UTC)
Maytag Washer fills up and then nothing happens (Washer Repair)
by indrohrer 1/12/2012 6:57:38 AM(UTC)
A red light turns flashes on but nothing happens (Dryer Repair)
by novodinia 12/2/2011 3:51:36 PM(UTC)
Front loader - Door lock is on nothing happens (Washer Repair)
by xplore 6/3/2011 12:44:38 PM(UTC)
Washer full of water,timer at rinse,alarm sounded, nothing happens. (Washer Repair)
by BobB15 4/29/2011 2:44:04 PM(UTC)
When I turn knob to start the washer all lights come on and nothing happens (Washer Repair)
by crystal blankenship 12/13/2010 1:13:29 PM(UTC)
Timer runs but nothing happens (Dishwasher Repair)
by Rising 12/9/2010 7:21:22 PM(UTC)
My front load washer will not start. push start and nothing happens (Washer Repair)
by kimmoe 1/4/2010 2:54:50 PM(UTC)
by vic_3599 10/6/2008 1:31:55 PM(UTC)
Washer humms but nothing happens (Washer Repair)
by Confalone 11/16/2007 2:36:51 PM(UTC)
Nothing Happens, All Lights flash (Washer Repair)
by Survivor 9/19/2007 1:54:25 PM(UTC)
