redouse
#1 Posted : Friday, January 15, 2010 4:08:34 AM(UTC)
redouse
The washer takes a very long time on the normal setting, reverses direction very slowly or takes a long time to reverse. Heavy and light settings seem normal. Is the motor control board going bad?
Gary
sidfink43
#2 Posted : Saturday, January 16, 2010 5:56:12 PM(UTC)
sidfink43
Possible, but it may also be your main control board. Here is a Maytag tech bulletin on the new motor/motor control assembly. If you contact Maytag they made send you a unit free of charge.
http://www.servicematters.com/m...rary/docs/TDL-0018-B.pdf
redouse
#3 Posted : Saturday, January 16, 2010 6:08:19 PM(UTC)
redouse
The washer is about 10 years old and has been updated and rebuilt once about 5 years ago under a warrenty(same problem). My understanding is that Maytag is no longer in business.
sidfink43
#4 Posted : Sunday, January 17, 2010 5:15:34 AM(UTC)
sidfink43
Maytag is owned and operated by Whirlpool. They did such a disasterous job with the Neptunes that they only way they could survive was to sell to Whirlpool, and they did and are still running.
See if you can remember or find documentation on what they did before, and then replicate the work.
redouse
#5 Posted : Sunday, January 17, 2010 6:03:48 AM(UTC)
redouse
They replaced everything. motor, motor control, circuit boards, wax door latch, door seal so I am not sure what the item was that made it work.
I have not had a warrenty on it since then. 5 years ago
Do you think Whirlpool will today fix it for free on a recall of sorts?
sidfink43
#6 Posted : Sunday, January 17, 2010 6:48:07 AM(UTC)
sidfink43
No, Maytag/Whirlpool will not fix this machine free, and given they have changed it out once I doubt if they will even supply parts.
If you have gotten 10 years out of this model you are way ahead of the game. I suggest that rather than sinking more time or money into it you replace it with a good, no frills top loading machine. Make sure it does not have microprocessor controls, for reasons you have already experienced.
redouse
#7 Posted : Sunday, January 17, 2010 6:54:14 AM(UTC)
redouse
Thanks for all your help.
I will be looking for a cheap top loader, Kenmore,Whirlpool or Roper.
Have a great day
sidfink43
#8 Posted : Sunday, January 17, 2010 6:58:17 AM(UTC)
sidfink43
You are welcome, good luck and I am sure you will get a very good machine. Retailers seem a little desperate right now.
maytag washer problem (Washer Repair)
by donvd 7/28/2013 5:17:57 PM(UTC)
Maytag washer problem (Washer Repair)
by tom luse 5/9/2013 8:12:39 AM(UTC)
by AFTERTHOUGHTS 7/28/2012 7:56:54 AM(UTC)
maytag washer problems (Washer Repair)
by djv106 9/24/2011 7:40:00 AM(UTC)
by SAYRES 9/11/2011 5:52:04 AM(UTC)
by cherylted 8/8/2011 9:29:34 AM(UTC)
by cherylted 5/26/2011 1:42:36 PM(UTC)
Maytag Washer Problems (Washer Repair)
by Jim Fedewa 2/18/2011 5:01:40 AM(UTC)
Maytag Washer Problem (Washer Repair)
by richard levy 2/20/2010 9:09:27 AM(UTC)
maytag washer problem (Dishwasher Repair)
by nowash 4/25/2009 3:02:25 PM(UTC)
by parker4628 3/18/2009 4:49:01 PM(UTC)
by Mike B 8/28/2008 1:44:12 PM(UTC)
