mikejohnston5
#1 Posted : Tuesday, January 12, 2010 7:48:15 AM(UTC)
mikejohnston5
My washer was leaking a few weeks ago so I took off the cover to find the source. At the beginning of the first spin cycle, water was coming out between the plastic inside drum and the metal outside drum. I unsnapped the tabs and found the gasket in there to look worn. At the front of the washer, the plastic and metal were touching so I figured the gasket was worn. I bought a new gasket and replaced it. Still, I have some water leaking out. The plastic and metal still nearly touch in the front.
Is there anything I can do to get this washer to stop leaking!?
sidfink43
#2 Posted : Thursday, January 14, 2010 4:40:27 PM(UTC)
sidfink43
See if the discussion on re-centering the basket will help you. Here is the service manual
http://www.servicematters.com/m...6010373%20(16001145).pdf
mikejohnston5
#3 Posted : Friday, January 15, 2010 6:13:41 PM(UTC)
mikejohnston5
Thanks for the response.
Unfortunately, that didn't fix the problem. I double/triple checked that the tabs are right in the depressed spots in the metal. I can see the gasket between the plastic and metal around the back and sides. In the front, the plastic and metal tough (or are very close). This is where the water is coming from.
I checked the plastic and there aren't any imperfections. The gasket is brand new so that couldn't be it.
I wonder if there is something missing on the inside of the outer ring of the metal tub. Do you know what exactly is sealing off on the metal?
On another note, I never had a manual for the washer so thanks!
sidfink43
#4 Posted : Saturday, January 16, 2010 3:31:48 PM(UTC)
sidfink43
Unfortunately not having one of those models in front of me means I can only refer you back to the service manual and the pictures and discussion. there. Yours is an unusual problem and without being there to see it I am at kind of a loss. Maybe someone else can chime in here and be helpful.
stubborn tub nut, leaking tub, loud noise (Washer Repair)
by stubborn nut 10/24/2014 5:14:20 PM(UTC)
Leaking Tub Seal (Washer Repair)
by randyowens 2/8/2014 11:14:55 AM(UTC)
Any way to re-seal leaking tub on Frigidaire Affinity washer (Washer Repair)
by curious14 7/17/2013 5:59:30 PM(UTC)
Leaking tub (Washer Repair)
by jjenks22 11/25/2011 4:33:37 PM(UTC)
leaking tub (Washer Repair)
by thesulman 8/8/2010 9:27:02 AM(UTC)
Leaking tub seal but have no model number can anybody help (Washer Repair)
by dirtclaud007 9/13/2009 6:48:03 PM(UTC)
Frigidaire Stackable W/D, leaking tub seal (Washer Repair)
by FDAR 7/9/2009 11:48:13 AM(UTC)
Leaking tub seal/bearing (Washer Repair)
by Mike Luke 10/9/2007 5:05:34 PM(UTC)
