4 Pages123>»
John G
#1 Posted : Monday, March 10, 2008 6:14:17 PM(UTC)
John G
The turntable starts to turn about 1/2 a revolution and stops. I am thinking that it is the turntable motor that needs replaced on this unit that is mounted in our kitchen. The glass tray turns freely with no resistance. Could it be some other problem?
If I purchase a replacement motor, is it hard to install? Can it be replaced from under the unit without removing it from the wall bracket?
Do you have any replacement instructions to follow?
I know this is a lot of questions, but any help would be appreciated.
#2 Posted : Tuesday, March 11, 2008 1:41:30 PM(UTC)
Hi John,
The first thing I would check is the coupler (#37 on the break down diagram).
Remove the glass tray and pull the coupler up. Check it for any cracks.
If the coupler is fine then the turntable motor has to be replaced.
It can be easy replaced after the bottom panel removed - just two screws and the wire plug.
- The part number for the coupler is AP2016754
- The part number for the turntable motor is AP2024962
Here are the break down diagrams for the GE microwave Model JVM1860SD001
John G
#3 Posted : Wednesday, March 12, 2008 6:22:30 AM(UTC)
John G
Gene:
Thanks for the quick response.
John G
rahulbpatel
#4 Posted : Tuesday, June 10, 2008 8:33:33 AM(UTC)
rahulbpatel
We're having the same problem with our Jenn-Air JMC7000ADB microwave -- the turn table does not turn. The spindle turns when the glass tray is off but will not turn when it's on there. I'm pretty sure the motor needs to be replaced. Is this something that can be performed by a weekend DIYer or does it need to be done by a professional? Here is the part:
MAYTAG Motor, turntable, part number: 56001231
Thanks...
#5 Posted : Tuesday, June 10, 2008 2:45:06 PM(UTC)
This part is not too difficult to replace yourself if you know how to handle a simple hand tools.
Here are the break down diagrams for the Jenn Air microwave Model JMC7000ADB
skimaniac6
#6 Posted : Saturday, September 13, 2008 11:33:31 AM(UTC)
skimaniac6
I am also having this problem with a GE spacemaker xl1800. I am also having trouble with the light, it doesn't work on the first (low) setting but does on the high setting. Any help would be great.:)
#7 Posted : Saturday, September 13, 2008 2:42:15 PM(UTC)
skimaniac6,
What is the complete model number of the microwave? You can find it inside the microwave.
skimaniac6
#8 Posted : Monday, September 15, 2008 10:05:54 AM(UTC)
skimaniac6
Thanks for the quick reply, sorry I should have thought of that. model JVM 1860BD 001.
Thanks again.
Scott:)
#9 Posted : Monday, September 15, 2008 1:56:03 PM(UTC)
Hi Scott,
Looks like the control board is bad because it controls all functions of the microwave, including the surface lights.
- The part number for the control board is AP3192717
Here are the break down diagrams for the GE microwave Model JVM1860BD001
skimaniac6
#10 Posted : Monday, September 15, 2008 3:01:36 PM(UTC)
skimaniac6
Sorry to not be more clear, the light problem started about 1 year ago and the turntable happened after we put a large heavy dish in and forgot to turn the turntable off. It still seems to spin till you put the glass plate on, then it won't turn. I can live without the nightlight function but not the turntable.
Thamks again.
Scott
Guest (10)
Microwave turntable will not turn (Microwave Repair)
by janetlmo 6/16/2009 10:07:08 AM(UTC)
4 Pages123>»
