James E Rogers
#1 Posted : Monday, January 11, 2010 4:57:48 PM(UTC)
James E Rogers
I have to replace the freezer door gasket. (Bottom mount freezer). Can the freezer door be removed, for gasket replacement, without removing the big upper refrigerator door on this model Kitchen aid?
#2 Posted : Tuesday, January 12, 2010 2:39:14 AM(UTC)
Replacement parts for WHIRLPOOL KBRS22KKWH00 | AppliancePartsPros.com
Here is a manual which may help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e6dde8efcb9e0f485256ab00056337f/$FILE/4322228.pdf
I can see no reason why not but have never done it.
I would pull the unit forward, then you can block up the hinge/foot side of the unit. Then remove the bottom hinge to remove the door.
This will probably require two people as the door will have to be supported for you to get the hinge off/on easily.
KBUDT4270A/02 SXS freezer door gasket (Refrigerator & Freezer Repair)
by metropical 3/19/2022 9:56:33 AM(UTC)
What Freezer Door Gasket Do I need (Refrigerator & Freezer Repair)
by mjrddell 7/17/2015 9:38:53 AM(UTC)
Whirpool freezer door gasket not sealing (Refrigerator & Freezer Repair)
by tannerthehammer 5/11/2013 11:20:13 AM(UTC)
Replacing Whrilpool freezer door gasket (Refrigerator & Freezer Repair)
by jerryrump 11/25/2012 7:36:43 AM(UTC)
Bottom freezer door gasket replacement (Refrigerator & Freezer Repair)
by PageinSC 7/18/2010 7:42:53 AM(UTC)
by grenoble 4/9/2010 7:23:57 AM(UTC)
Replacing freezer door gasket (Refrigerator & Freezer Repair)
by vynnette 2/14/2010 2:44:24 PM(UTC)
Amana refrig/freezer door gasket replace (Refrigerator & Freezer Repair)
by Lulalake 10/24/2009 9:59:16 AM(UTC)
Replacing food/freezer door gasket/seal (Refrigerator & Freezer Repair)
by mskalisiak 5/18/2009 6:51:34 AM(UTC)
Freezer door gasket to long (Refrigerator & Freezer Repair)
by snipersgt216 1/13/2009 2:30:20 PM(UTC)
Freezer door gasket (Refrigerator & Freezer Repair)
by snipersgt216 1/5/2009 3:58:43 PM(UTC)
Freezer Door Gasket (Refrigerator & Freezer Repair)
by EJwins 11/11/2008 11:26:52 AM(UTC)
