dmstelk
#1 Posted : Saturday, January 9, 2010 7:55:03 PM(UTC)
dmstelk
My double oven along with most of my neighbors in a six year old neighborhood quit working. We all replaced the control panel. Another one quit working so I repaced their contol panel but there is nothing at the control panel. Also the interior lights do not come on when doors are open.
#2 Posted : Sunday, January 10, 2010 7:04:49 AM(UTC)
Replacement parts for WHIRLPOOL RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208302068.pdf
And a manual which should help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Looks like the oven lights are controlled through the board so that would explain why they are not working.
Could be the transformers primary winding thermal fuse is blown, see Page 3-2 in the manual.
If OK check that there is voltage out of the transformers secondary, I think it should be around 24 volts.
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
Thermador Double Oven not working properly (Oven Repair (including Ranges and Cooktops))
by rxrep 12/28/2014 10:32:11 AM(UTC)
Maytag Gemini Double oven not working (Oven Repair (including Ranges and Cooktops))
by MTODD101 11/14/2014 1:01:34 PM(UTC)
by Mck236 10/18/2014 8:06:46 PM(UTC)
GE double oven not working (Oven Repair (including Ranges and Cooktops))
by bigreed67 2/19/2009 9:25:52 PM(UTC)
