tisch
#1 Posted : Wednesday, January 6, 2010 10:02:55 AM(UTC)
tisch
I ordered replacement glass for the outside of the oven door. It won't fit into the vent/handle piece with the trim pieces on either side.
The original glass is no longer manufactured, but this is the replacement piece from Whilrpool.
I thought this would be an easy fix.
Am I doing something wrong?
#2 Posted : Wednesday, January 6, 2010 12:38:21 PM(UTC)
Cannot say what you are doing wrong, if anything perhaps the following will help
https://secured.whirlpoo...5ef62c/$FILE/8178042.pdf
Part Details - WHIRLPOOL Glass, Outer door, part number: AP3120448
If you click on the picture of the correct glass you should be able to figure out what the dimensions of the replacement glass should be using the one inch grid.
Black Oven Door Glass, not sure model? (Oven Repair (including Ranges and Cooktops))
by amemary 12/29/2013 1:09:12 PM(UTC)
Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by Amsel7 11/29/2013 7:26:50 AM(UTC)
inner oven door glass broken (Oven Repair (including Ranges and Cooktops))
by 1pooldoc 12/15/2012 4:13:12 PM(UTC)
cracked inner oven door glass (Oven Repair (including Ranges and Cooktops))
by debbl1412 7/19/2012 9:34:49 AM(UTC)
Kitchenaid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by drill 1/6/2012 5:48:30 AM(UTC)
electrical oven door glass (Oven Repair (including Ranges and Cooktops))
by RTOates 1/1/2012 6:57:27 PM(UTC)
Amana oven door glass and trim (Oven Repair (including Ranges and Cooktops))
by captainpegs 5/2/2011 5:46:28 PM(UTC)
Oven Door Glass Repair (Oven Repair (including Ranges and Cooktops))
by jvkonieczka@prodigy.net 4/27/2011 11:49:40 AM(UTC)
Outer oven door glass (Oven Repair (including Ranges and Cooktops))
by luger1 2/12/2011 1:19:04 PM(UTC)
Whirlpool Oven Door Glass Removal (Oven Repair (including Ranges and Cooktops))
by hkrauss 7/29/2010 1:50:51 PM(UTC)
Broken Oven Door Glass (Oven Repair (including Ranges and Cooktops))
by JasonKaleta 5/1/2010 9:50:29 AM(UTC)
Glass oven door glass is dirty between the two glass (Oven Repair (including Ranges and Cooktops))
by mhobbs 3/27/2010 12:54:35 PM(UTC)
KitchenAid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by gglbox 3/8/2010 6:18:55 PM(UTC)
Broken Oven door glass (Oven Repair (including Ranges and Cooktops))
by Mike-mcd 1/20/2010 4:44:50 PM(UTC)
Inner Oven Door Glass (Oven Repair (including Ranges and Cooktops))
by doniris 11/3/2009 12:28:22 PM(UTC)
