Can I take my glass oven door appart so that I can clean the glass that got badly streaked when the oven was self cleaning? I do know that the oven door can be removed very easily.
Originally Posted by: mhobbs  Can I take my glass oven door appart so that I can clean the glass that got badly streaked when the oven was self cleaning? I do know that the oven door can be removed very easily. How do you remove the glasspanels on the doors to clean the inside of the glass??????????????
Originally Posted by: mhobbs  Can I take my glass oven door appart so that I can clean the glass that got badly streaked when the oven was self cleaning? I do know that the oven door can be removed very easily. I had that same question, and YES you can take it apart to clean, but I am still trying to figure out HOW to go about it...
Originally Posted by: Yohekat  I had that same question, and YES you can take it apart to clean, but I am still trying to figure out HOW to go about it... I called the 1-800 number and the representaive stated that it is not designed for consumer removal. It is recommended to be cleaned by a service technician. I know this is of no help but it is the company's direction provided. Good Luck!
