buckeyes007
#1 Posted : Monday, January 4, 2010 7:39:46 AM(UTC)
buckeyes007
I have a PSC23NSTDSS serial # RL449436. It's only 3 years old and my wife noticed that the refrigerator side wasn't cooling properly. It is set at 35, but the digital reading says its 49. The freezer is set at 0, but it says its 2. The ice is melting in the ice maker. Please help!
Thanks,
Chris
buckeyes007
#2 Posted : Monday, January 4, 2010 9:58:20 AM(UTC)
buckeyes007
Okay, trying to do some diagnotics. I am trying to get the back panel off, but i am having problems. Do you have to take the brackets off where the shelves were? If so, what tool do you have to use?
#3 Posted : Monday, January 4, 2010 10:48:30 AM(UTC)
Quote:
... Do you have to take the brackets off where the shelves were? If so, what tool do you have to use?...
Yes, you do have to remove the brackets and the rear panel in the freezer to inspect the evaporator coils. You'll need a Phillips screwdriver and a 1/4" nut driver.
Also, remove the rear cover from the refrigerator and make sure the condenser is clean and the fan next to the compressor works properly.
Here are the breakdown diagrams and Replacement parts for General Electric PSC23NSTDSS Refrigerator | AppliancePartsPros.com
buckeyes007
#4 Posted : Monday, January 4, 2010 11:12:56 AM(UTC)
buckeyes007
Gene,
Thanks for the info! I was able to remove the panel and discovered the frost all over the coils. I cannot find the defrost timer. Do you know if this model has one?
#5 Posted : Monday, January 4, 2010 11:23:27 AM(UTC)
This model does not have any defrost timers. There is main control board on the back of the refrigerator, which controls all functions. You can find some test instructions in one of our previous threads: http://forum.appliancepartspros...igerator-too-warm-3.html, in the reply addressed to bohemian.
buckeyes007
#6 Posted : Wednesday, May 12, 2010 12:50:17 PM(UTC)
buckeyes007
I replaced the main control board and I am still having problems. I just ordered the thermostat def (WR50X10069) and the sensor temp ff (WR55X10025), however it did not come with any instructions. How difficult is it to replace these two parts? Does the freezer have to be totally defrosted?
buckeyes007
#7 Posted : Wednesday, May 12, 2010 1:38:29 PM(UTC)
buckeyes007
Looks like some wires need to be spliced. Can I use regular electrical tape or is there special tape to use in the freezer?
#8 Posted : Thursday, May 13, 2010 7:40:50 PM(UTC)
The best thing is to use a wire nuts and cover them with a regular insulation tape..
