Ice maker makes ice, then all the ice in the ice bin melts into the freezer. The bottom half of the freezer is frozen, but it seems the top of the freezer is warmer, allowing the ice to melt. I have a digital display for the temp. of the freezer and it fluctuates from -5 to +1 all by itself. Usually when the temp is on the warm side around -1 is when the ice melts. Could I need a new mother board?
Got back there, it was filthy. Keeping my fingers cross!!
Good luck. Keep us posted.
nonetheless Gene, thank you for the advice!
Well its been a few days, freezer is doing its job by keeping the ice cold enough not to melt. Thanks again for the cleaning tip!!!
ice started melting again..........any suggestions?
Originally Posted by: dbaas  ice started melting again..........any suggestions? Any unusual sounds or anything else unusual? What is the exact temperature in the freezer? Gene.
