Freezer ices up even after I have changed the defrost heater and the thermostat assembly...
Hi Carlos, Most likely the problem with your fridge is a bad adaptive defrost control (#13 on the controls break down diagram). This is most common problem for Maytag refrigerators in last 10 years. - The part number for the adaptive defrost control is AP3160614 Here are the break down diagrams for the Maytag refrigerator Model MSD2458GEBGene.
Thank You Very Much This Was Right
I'm glad you were able to fix it.
