bhartzog1976
#1 Posted : Sunday, December 13, 2009 5:22:10 PM(UTC)
bhartzog1976
I have a GE washer that has started to make an infrequent scrapping noise during the wash cycle and a really loud humming noise during the spin cycle was wondering if anyone had any idea what might be causing this thanks
sidfink43
#2 Posted : Tuesday, December 15, 2009 1:21:06 PM(UTC)
sidfink43
The main way we diagnose a noise is to listen to it and determine where it is coming from. In a Forum like this we cannot do this, so our advice is limited.
I suggest you take off the front, which you can do by inserting a putty knife or thin screw driver in the gap between the top and the front near the edges. This will release clips which hold the front on.
You can now listen to the noise as you operate the machine. I suspect you will find it is coming from the transmission, which also houses the brakes which may be hung up or slipping. Also listen to see if it is the motor or the clutch which is on the motor.
bcgreene
#3 Posted : Tuesday, December 22, 2009 3:39:52 PM(UTC)
bcgreene
How do i check for leaks. My wife moved the washer today and now it tripps the circuit???
Model #WPRB8050D1WW.
sidfink43
#4 Posted : Tuesday, December 22, 2009 4:08:04 PM(UTC)
sidfink43
Hi BC
Please start your own thread, and if you can give a more detailed description of what was done with the machine and why you think a leak is the problem when it tripping your GFI.
I am sure someone will be able to help you.
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
GE profile washer won't start (Washer Repair)
by Blecun 2/10/2020 7:05:41 AM(UTC)
Control panel for GE Profile washer (Washer Repair)
by AmyC_1012 7/25/2018 7:50:00 AM(UTC)
GE Profile washer clogged air dome (Washer Repair)
by pgr8house 8/6/2017 2:26:23 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
GE Profile Washer Dripping When Not in Use (Washer Repair)
by Sara6181 6/11/2017 10:17:06 AM(UTC)
GE Profile washer won't fill all the way (Washer Repair)
by jimlansing 1/16/2016 4:29:14 PM(UTC)
GE Profile washer - washes, drains, no spin (Washer Repair)
by cgiuffre 1/6/2016 6:06:10 PM(UTC)
GE Profile Washer won't spin only on delicate setting (Washer Repair)
by balmoral201 3/28/2015 12:28:37 PM(UTC)
GE Profile Washer Stops during filling & wont rinse (Washer Repair)
by KLS2015 3/22/2015 7:26:19 PM(UTC)
GE Profile Washer water level knob is stuck (Washer Repair)
by jj605v 12/29/2014 2:03:41 PM(UTC)
Ge Profile Washer Over Fills (Washer Repair)
by APPLIANCEDUDE1972 12/28/2014 5:56:26 PM(UTC)
ge profile washer (Washer Repair)
by Mike Elliot 12/7/2014 7:33:29 AM(UTC)
GE profile washer repeats the rinse cycle (Washer Repair)
by darylp 12/2/2014 3:53:03 PM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
