mtrimboli
#1 Posted : Saturday, March 1, 2008 11:26:15 AM(UTC)
mtrimboli
water pools in bottom of refrigerator. No water is going into drip pan under fridge. Defroster hose clogged. How do I clean it out?
mtrimboli
#2 Posted : Saturday, March 1, 2008 12:45:18 PM(UTC)
mtrimboli
the correct model number is GS21HTZBBO
mtrimboli
#3 Posted : Saturday, March 1, 2008 1:21:06 PM(UTC)
mtrimboli
still asking anyone
I tried unplugging the fridge and letting any ice that was in the system to melt.
I tried sticking all kinds of wires down the tube under the coils in freezer: coat hanger- too stiff, speaker wire-too limp, even got desperate and tried a plumber's snake---all would not go too far.
I tried to stick wires up from the bottom of the tube down where it is supposed to empty into the drain tray. No success.
What kind of wire can I use?
#4 Posted : Sunday, March 2, 2008 1:45:25 PM(UTC)
Do not use any wires - you can damage the drain hose.
Using a hair dryer make sure the drain is defrosted. Check the bottom end of the drain hose for a clog.
Using a hot water check if it goes through. If it does not then blow an air under pressure through the hose. You can use any kind of canned air.
Water in bottom of fridge (Refrigerator & Freezer Repair)
by sprckngray 4/23/2009 2:41:43 PM(UTC)
Leaks water in bottom of fridge (Refrigerator & Freezer Repair)
by nitroman 4/4/2009 7:27:06 AM(UTC)
