mikep
#1 Posted : Friday, February 29, 2008 4:47:39 AM(UTC)
mikep
the timer appears to get stuck about half way thur the wash cycle. The machine continues to run but will just stay there. If i manually turn past the point where it sticks then the machine finishes washing fine. The place where it gets stuck is at approximatley 7 o'clock on the dial. Thanks for any help
#2 Posted : Friday, February 29, 2008 12:23:18 PM(UTC)
Most likely it was paused for the water heating and if incoming water temperature is much lower than required 120° - it could take more then two hours to finish the cycle.
For any further questions I need the complete model number of the dishwasher.
mike313t
#3 Posted : Wednesday, May 6, 2009 7:19:50 PM(UTC)
mike313t
Hi, I have the same issue with Frigidair Dishwasher, Model #: FDBB240FB0. The dishwasher is about 2 years old. It used to take about an hour and a half, but now it takes over 2.5 hours. Is it an issue with a timer? If a timer is a problem, is there any way to repair the timer, since the new ones are over $100. Thanks
#4 Posted : Wednesday, May 6, 2009 10:48:01 PM(UTC)
Most likely the problem is a faulty water heater or the high limit thermostat. You have to check them for continuity.
Here are the breakdown diagrams and Replacement parts for FRG FDBB240FB0 | AppliancePartsPros.com
mike313t
#5 Posted : Saturday, April 17, 2010 11:42:52 AM(UTC)
mike313t
Hi Gene, how can I tell if it's a faulty water heater or the high limit thermostat? Also, now there seems to be a problem with the soap dispenser, when the cycle completes, there is still soap running down... Thanks
#6 Posted : Saturday, April 17, 2010 5:08:44 PM(UTC)
As I said previously, you have to check them for continuity.
The problem with the dispenser could be because of cold water or old soap.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
mike313t
#7 Posted : Saturday, April 24, 2010 10:55:47 PM(UTC)
mike313t
Gene,
Where is the high limit thermostat located in this model?
Thanks,
Mike
#8 Posted : Sunday, April 25, 2010 1:08:54 PM(UTC)
Mike,
The thermostat shown as #29 on the diagram. It's located under the tub on the left side.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Frigidaire dishwasher fills and drains does not wash (Dishwasher Repair)
by Guest 9/19/2023 12:06:34 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
I20 error on brand new Frigidaire dishwasher (Dishwasher Repair)
by Guest 2/8/2023 6:50:55 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire dishwasher Model # LFID2422RF4B (Dishwasher Repair)
by lharwerth 11/22/2021 7:15:45 AM(UTC)
Frigidaire dishwasher ffbd2406nb3a no cleaning the dishes (Dishwasher Repair)
by Yolando 4/6/2021 5:50:57 PM(UTC)
Frigidaire Dishwasher ffbd2411ns1a Noise (Dishwasher Repair)
by bdwashburn 8/3/2020 11:11:43 AM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Frigidaire Dishwasher FDB1250REC0 no lights (Dishwasher Repair)
by Idesignedit 9/2/2019 9:37:32 AM(UTC)
Frigidaire Dishwasher FFBD2406NB0A (Dishwasher Repair)
by Brian P Mark 4/18/2019 4:54:21 AM(UTC)
Frigidaire Dishwasher LGID2475QF5A i20 error code (Dishwasher Repair)
by 210matt 11/4/2018 3:32:21 PM(UTC)
Frigidaire Dishwasher Soap Still Remains (Dishwasher Repair)
by Kryptonite 4/5/2018 12:21:21 PM(UTC)
*plz Help* Frigidaire Dishwasher Top Sprayer Will Not Work *plz Help* (Dishwasher Repair)
by Timma9705 2/21/2018 8:14:48 AM(UTC)
