ZONIE24
#1 Posted : Wednesday, December 16, 2009 10:25:20 AM(UTC)
ZONIE24
I Have A Roper Ras7133kqi And It Works Fine Except For The Spinning Cycle. I Don't Hear A Noise Or Anything It Just Will Not Spin
sidfink43
#2 Posted : Thursday, December 17, 2009 4:58:48 PM(UTC)
sidfink43
Well, the first thing you want to do is to by-pass the lid switch because it doesn't cost anything to do so. This site will show you how.
If that does not make it spin, go ahead and take off the cabinet and take off the pump. Check to see that it is not jammed. This is not likely since the machine apparently agitates, but again, no cost to check.
If these are not the problem, take off the motor and leave it connected and see if it turns when the machine is in spin mode. (keep the lid switch by-passed) If the motor turns, your problem is in the transmission/clutch break area, and I would visit Richappy's stick at the top of the page for further advice.
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
Belarus craig100 3/15/2024 9:35:49 AM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Machine goes through cycle but won't spin (Washer Repair)
by Guest 9/12/2021 10:04:44 AM(UTC)
Whirlpool cabrio won't spin out (Washer Repair)
by Guest 7/28/2021 7:22:56 AM(UTC)
Pumps but won't spin or drain (Washer Repair)
by Guest 6/21/2021 2:45:48 PM(UTC)
SQ Washer Tub Won't Spin Still After Initial Troubleshooting (Dishwasher Repair)
by vamazzeo 4/16/2021 10:00:33 AM(UTC)
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4/7/2021 4:58:55 PM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
GE Top Load washing machine, won't spin & won't stop cycling (Washer Repair)
by Stefano31 9/29/2020 3:01:44 PM(UTC)
DV448AEP/XAA Dryer Won't Spin (Dryer Repair)
by hufe1983 1/13/2020 4:48:55 PM(UTC)
Won't spin fast - only slow (Washer Repair)
by Machine_Slo 1/6/2020 9:16:58 PM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
