3 Pages123>
Charles Neighbors
#1 Posted : Tuesday, December 8, 2009 4:59:25 AM(UTC)
Charles Neighbors
I have looked at the posts. Mine is a little different.
My crisper is turning into a freezer which also causes the water line to freeze. Top of the fridge is warmer than the bottom. On the freezer side the bottom is cold but the ice maker is hot, there is water in the unit but it will not freeze. Help:confused:
#2 Posted : Tuesday, December 8, 2009 5:18:52 PM(UTC)
What is the complete model number of the refrigerator?
Charles Neighbors
#3 Posted : Thursday, December 10, 2009 4:44:21 AM(UTC)
Charles Neighbors
Gene,
The Model number is GSL25JFPH BS
#4 Posted : Thursday, December 10, 2009 1:02:46 PM(UTC)
Turn the ice maker off or unplug its wire harness and watch the refrigerator for a few hours. Put more attention on the cold air flow through the damper control (#426 on the diagram). Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSL25JFPHBS Refrigerator | AppliancePartsPros.com
jaxcarlson
#5 Posted : Thursday, December 10, 2009 2:15:42 PM(UTC)
jaxcarlson
I am having pretty much the same issue as Charles. My bins in the fridge side are freezing, and the freezer is not freezing on the top part. I took the plate out in the back of the freezer and saw the coils are frozen over in the middle third, but not so much frozen over in the top and bottom thirds. I have a GE side by side, model GSS25TSRE. Any tips would be appreciated, and I will unplus the icemaker assembly like you suggest and look at the damper control.
#6 Posted : Thursday, December 10, 2009 3:17:32 PM(UTC)
You refrigerator has a different design compared to the one owned by Charles. The problem you described has nothing to do with the ice maker because yours is not hot. Watch the damper control and post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25TSRESS Refrigerator | AppliancePartsPros.com
jaxcarlson
#7 Posted : Thursday, December 10, 2009 3:45:11 PM(UTC)
jaxcarlson
After doing some searching it appears it may be the thermistor or the thermostat. Is there a way to check the thermistors, or should I replace them since they are relatively cheap anyway (compared to a service call)?
#8 Posted : Thursday, December 10, 2009 3:50:05 PM(UTC)
The best way is to diagnose exact problem and then fix it. Guessing is not the way I'd like.
So far the problem with your refrigerator can be a bad damper control or a faulty defrost system.
Charles Neighbors
#9 Posted : Monday, December 14, 2009 5:19:17 AM(UTC)
Charles Neighbors
Gene,
I checked the Fridge several times this weekend, with the ice maker off.
When the Fridge door is closed (holding the button) the Damper stays open all the time. When the fridge is open it closes. When I left the damper unpluged the water despenser works after is thaws out. Tried plugging in the damper and turning on the power to the ice maker, still no ice and the water line froze back up.
Charles Neighbors
#10 Posted : Monday, December 14, 2009 5:20:34 AM(UTC)
Charles Neighbors
Gene,
P.S. the air flow going from the damper to the Frezzer did not seem to fast.
:confused:
Guest (6)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
3 Pages123>
