jeffrey l
#1 Posted : Friday, December 4, 2009 5:27:23 PM(UTC)
jeffrey l
The oven heating element melted down. I ordered a new one and replaced it but it will not heat. the broiler works as does the stove top, clock etc.
When the original element melted down, is there another part that I might also need to replace or is it possible that the "new element" is defective?
Is there a way to test this?
There is something under the cooktop that is labeled a switch-snap acting...is this the same as a thermostat and could it have blown when the original element went?
Is there a diagnostic process to go thru to figure this out...can I take the broiler connections and put them on the oven element to see if it heats?
Jeff
#2 Posted : Saturday, December 5, 2009 3:25:02 AM(UTC)
DUPLICATE
Pleas seee the following thread
http://forum.appliancepartspros...ing-heating-element.html
jeffrey l
#3 Posted : Tuesday, December 15, 2009 4:38:00 AM(UTC)
jeffrey l
Closing this thread...when the bake coil blew it melted the solder on the relay board so while the relay was clicking there was not link to the bake element. Replacing the relay board fixed it. Thanks for all your help!
Jeff
#4 Posted : Tuesday, December 15, 2009 5:12:38 AM(UTC)
You are welcome
Thanks for getting back to us.
I hope you do not mind but I am going to add this post to your other thread.
That way if someone has the same problem they will see your troubleshooting procedure and also the solution to the problem
Happy holidays to you and yours
Guest (4)
oven wont heat after replacing heating element (Oven Repair (including Ranges and Cooktops))
by jeffrey l 12/4/2009 5:26:47 PM(UTC)
