jeffrey l
#1 Posted : Friday, December 4, 2009 5:26:47 PM(UTC)
jeffrey l
The oven heating element melted down. I ordered a new one and replaced it but it will not heat. the broiler works as does the stove top, clock etc.
When the original element melted down, is there another part that I might also need to replace or is it possible that the "new element" is defective?
Is there a way to test this?
There is something under the cooktop that is labeled a switch-snap acting...is this the same as a thermostat and could it have blown when the original element went?
Is there a diagnostic process to go thru to figure this out...can I take the broiler connections and put them on the oven element to see if it heats?
Jeff
#2 Posted : Saturday, December 5, 2009 3:23:15 AM(UTC)
Replacement parts for MAGIC CHEF 6898VRV Range - S/c S/i Ele | AppliancePartsPros.com
A defective part is always a possibility. Unplug the unit, remove the element and check it with a meter. They are usually around 10 ohms.
I would say that it is a thermostat/thermal cut-off. But without a wiring diagram I cannot say what it is doing. It is possible that it is just for the bake element.
Unplug the unit and measure it with a meter, should be 0 ohms.
You could but it is easier and safer to use a meter.
240 volts is lethal.
If the above are OK then it becomes a crap shoot.
This unit uses a control board and a relay board. Without a wiring diagram it is difficult to diagnose the cause so the below is just supposition.
It looks like the relay board has the power supply to run the control board and the relays to run the oven elements.
If when you try bake you can hear the relay click in but the bake element does not come on then the odds are that it is the bake element relay that is shot and the relay board needs replacing
A couple things to note is that during preheat for bake most units alternate between the bake and broil elements to give a faster preheat.
Also the relay board has a third relay which may switch between the elements.
Just mentioned the above because it may be difficult to know which relay is closing for just the bake element.
Hopefully someone else will jump in with a wiring diagram or knowledge on this specific unit.
jeffrey l
#3 Posted : Saturday, December 5, 2009 11:25:52 AM(UTC)
jeffrey l
The bake element will heat when powered by the broiler relay but will not heat when powered by the bake relay. When you turn on bake, the bake relay closes and stays closed for about ten seconds and then opens adn seems to randomly open and close. I did find a schematic under the oven and it does say when the oven is on bake, the relay should cycle...other options listed for broil for this relay is open and closed for self clean.
The oven fan is activated when the oven is set to bake but the element does heat. Clock and front control panel seems to operate fine.
I removed the cover from the relay/solenoid and the contact do not look burn and they do close.
Ideas...
#4 Posted : Saturday, December 5, 2009 2:49:50 PM(UTC)
I am assuming that the above is a typo and you meant to say "but the element does not heat"
Up until the above I was sitting here thinking, it is the relay then I read that sentence and now it does not sound like the relay is the problem.
Check your wiring diagram to see if that thermostat is in the bake element's circuit path.
May also be an open wire.
It does sound like that for some reason the relay contacts are not completing the circuit to the bake element so there is a break in the circuit elsewhere.
One thing to check on the wiring diagram is that the current to the bake relay contacts does not go through the broil relay contacts (Normally closed). They sometimes do this so that the broil and bake elements can never be on at the same time.
I did notice that the relay board in the illustrated parts has 2 relays but has a spot for a third relay. If yours has a third relay then the current for the bake probably also goes through this relays contacts.
jeffrey l
#5 Posted : Saturday, December 5, 2009 6:16:49 PM(UTC)
jeffrey l
There are three relays but the third is labeled "fan" and seems to be on a separate circuit. The bake and broil relays pass to L1 thru a high limit switch and to L2 through the broil and bake elements.
If you have a fax I can fax the schematic to you just give me a number.
The oven control of course connects into the relay board.
If the hi limit switch was gone the broiler wouldn't work also would it?
So what I think I know sofar:
new bake element works if i run it through the broil relay but not the bake relay so element and wires appear to be good
control panel will set temperature and active bake but does not heat
when you turn on the bake cycle the fan relay activates the fan and it works
when you turn on the broil cycle the broiler works
When you turn on the bake cycle the solenoid in the bake relay clicks closed then opens and clicks again...but does sound a little funny, like a faster weaker click on some of the cycles. I assume this is allowing current to pass to the bake element but nothing happens. If I were to force the solenoid closed with a piece of plastic eg withthe power off and then power is up again would that tell me anything?
what else could be blown here? When the element went it did cause quite a few sparks until I turned off the bake oven.
Thanks again for helping me.
Jeff
jeffrey l
#6 Posted : Saturday, December 5, 2009 6:24:18 PM(UTC)
jeffrey l
and to answer a couple of your question...
the bake relay does seem to go ththe broil relay. The path on the schematic goes:
L2->bake element->to bake relay->from bake relay to line 1 jumper to broil relay with a split on the jumper that goes to the high limit switch which goes to L1. The L1 jumper to the broil relay goes through the broil relay ->broil element-> L2.
I hope this helps.
Jeff
#7 Posted : Sunday, December 6, 2009 3:45:29 AM(UTC)
Do not have a fax so only way I could get it is if you can post it on the internet and then link to it.
Yes it does sound like that is the way it is wire so we can eliminate the hi-limit as a cause.
This is strange. am not sure but I would have thought that on a bake preheat if the bake element turns off the broil element should turn on and the unit should cycle between the two.
If you force it closed and the element does not heat up then you know for sure that for some reason that bake relay contacts are not getting power.
Just be very, very careful 240 volts is lethal.
Sparks are usually bad news for the control board but since the bake relay is closing the element should heat up.
Is hard to tell if they are using Normally Open and Normally Closed contacts on the broil relay. I did do a Magic Chef search through this forum just to see how othe units that they make are wired and I could not find a unit where the did this so I am doubtfull the unit uses dul contacts on the broil relay.
_______\________BROIL ELEMENT____L2
l Broil Relay
l
L1 __\_____l
Hi-Limit l
l________\_______BAKE ELEMENT_____L2
Bake Relay
Looks like saving the above screws up my attempt at a drawing.
It should be L1 to the high limit.
Then the hi-limit to a parallel circuit.
One side of the parallel to the broil relay contacts then the broil element and L2
Other side of the parallel to the bake relay contacts then the bake element and L2
Note that the parallel (jumper) goes to the Common of both relays.
#8 Posted : Tuesday, December 15, 2009 5:18:05 AM(UTC)
jeffrey I
Closing this thread...when the bake coil blew it melted the solder on the relay board so while the relay was clicking there was not link to the bake element. Replacing the relay board fixed it. Thanks for all your help!
Jeff
oven wont heat after replacing heating element (Oven Repair (including Ranges and Cooktops))
by jeffrey l 12/4/2009 5:27:23 PM(UTC)
