Ignitor Glows, Checked The Ohm Reading ,was Less Than 100 Ohms,checked Continouity On Flame Sensor And Tested Ok,,doesn't Seem To Be Allowing Any Gas Into The Burner
Originally Posted by: dtallio Ignitor Glows, Checked The Ohm Reading ,was Less Than 100 Ohms,checked Continouity On Flame Sensor And Tested Ok,,doesn't Seem To Be Allowing Any Gas Into The Burner If the ignitor glows and then fades away without ignition, the usual culprit are the coils on the gas valve. See below. Part number: AP3094251
