afergus
#1 Posted : Friday, February 22, 2008 7:13:22 AM(UTC)
afergus
I have a Maytag range oven problem. I replaced the bake element (which was cracked in two) but the element will still not heat up. The broiler works fine.I don't know where to go from here. Please help!
roycreamer
#2 Posted : Friday, February 22, 2008 6:57:24 PM(UTC)
roycreamer
Groups: Expert
do the rest of the burners work ok? if not, reset your circuit breaker. the element can sometimes blow 1 side of a 220 line and it will light up like it's working, but will only get slightly warm.
roy
misterfixall
#3 Posted : Friday, February 22, 2008 7:31:33 PM(UTC)
misterfixall
if your broil is working normally ,the bake relay on the electronic clock probably shorted, which mean a new clock is needed
afergus
#4 Posted : Saturday, February 23, 2008 8:16:26 AM(UTC)
afergus
Reply to Misterfixall:
On the circuit board behind the clock, there is a melted area and the yellow wire going into the green plug does not show any power. Your suggestion was very helpful. We live in Alberta, Canada so if you have any suggestions for suppliers who ship internationally (parts appear to be cheaper in the US), we would appreciate it. The part cost here is quite expensive so it is not worth fixing unless we find a cheaper supplier. Thanks for your time.
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Maytag range oven (Oven Repair (including Ranges and Cooktops))
by C Hardin 10/30/2014 4:23:34 PM(UTC)
Maytag range lower oven not heating (Oven Repair (including Ranges and Cooktops))
by KA123 9/8/2014 6:10:19 PM(UTC)
Maytag Range Bake Light Flashing (Oven Repair (including Ranges and Cooktops))
by carlking2 12/26/2013 12:31:10 PM(UTC)
maytag range orifices (Oven Repair (including Ranges and Cooktops))
by chadk66 8/31/2013 3:38:29 PM(UTC)
Remove Maytag Range GlassTop, How to (Oven Repair (including Ranges and Cooktops))
by BobYates 4/7/2012 5:58:49 PM(UTC)
Maytag range clock control (Oven Repair (including Ranges and Cooktops))
by res04n70 12/27/2011 5:17:42 AM(UTC)
Maytag range (Oven Repair (including Ranges and Cooktops))
by txgbe270 8/21/2011 5:07:52 PM(UTC)
Maytag Range / MER5755QAQ (Oven Repair (including Ranges and Cooktops))
by jeffro390 6/6/2011 9:26:31 AM(UTC)
Maytag Range (Oven Repair (including Ranges and Cooktops))
by ADAMS48 6/1/2011 6:11:39 PM(UTC)
by Sanco777 5/13/2011 9:38:57 AM(UTC)
Maytag range. Cooktop functioning, but oven just says OFF (Oven Repair (including Ranges and Cooktops))
by watkinsnc 11/21/2010 10:21:52 AM(UTC)
Maytag Range lower bake element won't work (Oven Repair (including Ranges and Cooktops))
by donnabass8 11/17/2010 11:40:30 AM(UTC)
Any idea of naming scheme for Maytag ranges? (Oven Repair (including Ranges and Cooktops))
by rtom 11/9/2010 8:38:29 AM(UTC)
by specialfx 10/30/2010 6:34:39 AM(UTC)
