KA123
#1 Posted : Monday, September 8, 2014 6:10:19 PM(UTC)
KA123
The bottom heating element in the lower oven of my Maytag MER6875BCS range sparked and melted and after I replaced it the lower oven heats up very slowly and only tops out at about 200. I tested continuity on the new element and then on the thermostat and the temp probe. Everything seems fine. Is it the board? And how do I find one? It looks different than than say the MER6555 which is supposed to be a similar model.
Thanks in advance.
#2 Posted : Tuesday, September 9, 2014 1:46:35 AM(UTC)
Parts for Maytag MER6875BCS17 Range - AppliancePartsPros.com
I could not find one for a BCS unit but it is for all units up to a BAW unit so odds are yours is the same.
Yes it could be the board.
Looks like it may be obsolete.
It would be best to call AppliancePartsPros just to confirm this.
There are companies out there that repair obsolete control boards, just Google appliance timer repair
Does the broiler (upper element) work.
If not then a high limit switch may be open.
File Attachment(s):
MER6875.pdf (574kb) downloaded 10 time(s).
KA123
#3 Posted : Tuesday, September 9, 2014 7:12:51 PM(UTC)
KA123
The broiler does work, I tested what I believe to be the high limit switch, it looks like the link below:
Whirlpool 74009969 Hi-Limit Thermostat - AppliancePartsPros.com
It seemed to be fine, I even switched it with the one for the upper oven which I know works and the upper oven still works.
I am wondering by what the tech sheet indicated if I tested the temp probe properly, perhaps I may switch those and see if anything happens. Anyhow I will run the diagnostic and let you know what happens.
Thanks for the tech sheet!
#4 Posted : Wednesday, September 10, 2014 12:09:49 AM(UTC)
If the oven never comes ready (stays in preheat) then the oven sensor should be OK.
