2 Pages<12
mhill
#11 Posted : Wednesday, December 2, 2009 2:11:20 PM(UTC)
mhill
Originally Posted by: mhill Go to Quoted Post
I have the model 20, 22, 24 and I had the same problem. The water dispenser stopped working. But I heard something when I tried to dispense water like it was trying.
I took everything out of the freezer and turned it off. Then I took a heat gun and gingerly used it so it didn't get to hot. Hair dryer would work too. It freed right up and is working fine. I hope I don't have this problem again soon.
Thanks to this site for giving me the idea.
Yep, I did the same thing. Mine froze up again in a couple of days. I had someone come out and fix it. I watched him. It was tricky to get apart. I don't know if I would have figured it out without having watched him to it. Then he added a little kit which warms the line. Keeps it unfroze. Pretty simple but I'm pretty handy and was glad he did it. Without a step by step instruction I would have been lost.
#12 Posted : Wednesday, December 2, 2009 3:54:26 PM(UTC)
Originally Posted by: adwivell Go to Quoted Post
I'm having the same issue, I ordered a new control board and still no water. Lights on the front panel are not on. Does anyone else have any ideas for me. Thanks
What is the complete model number of the refrigerator?
Which control board have you replaced?
Does the ice dispenser work?
adwivell
#13 Posted : Thursday, December 3, 2009 1:37:54 AM(UTC)
adwivell
GE: GSS25XSQA
Board: WR55X10942
Nothing coming from the door works. No light, ice, or water but it still makes ice.
#14 Posted : Thursday, December 3, 2009 8:25:20 PM(UTC)
Check the wire harness under the freezer door. If there is nothing wrong, replace the dispenser control board.
- The dispenser control Part number: AP3205358
tphearse
#15 Posted : Saturday, February 23, 2013 6:38:12 PM(UTC)
tphearse
I tried this and it DID work... I emptied the fridge, blow dried the door edge while open for appx 10min (noticed it kept getting cold @ the bottom) kept it going for 20min more (inside corner, outside corner, under the door insulation & the ice dispenser shoot). Turned it back on, reset the filter & nothing!!!! BUT after trying ice, it dripped then a little pellet of ice dropped out & I had water!
2 Pages<12
