ERIC SEE
#1 Posted : Saturday, November 28, 2009 6:32:03 PM(UTC)
ERIC SEE
every thing on unit works great but unit doesent heat .please could someone give me a hint as to what may be problem i am verry machanical and can install any part needed. thanks
applianceman
#2 Posted : Sunday, November 29, 2009 9:53:29 AM(UTC)
applianceman
If it sounds as if it is working but you just don’t get any heat most of the time it is the magnetron tube. If it is louder than normal the problem can be the capacitor or the diode. The capacitor doesn’t give a lot of trouble and if the diode is bad I recommend changing the magnetron tube.
If you have a good ohmmeter you can check the diode but a lot of cheap meters won’t read diodes. Set the meter to the highest setting and check for ohms across the diode. It should be open one-way and high resistance the other (around 50,000 ohms or so). Often a bad diode will read low resistance both ways.
To check the capacitor unplug the wires and place the leads across it. The meter will read at first then go to nothing. Then if you reverse the wires on the ohmmeter it is do the same. If not the capacitor is bad.
This page will help you replace the magnetron GE Spacemaker Microwave Magnetron Tube Replacement
This page will help diagnose further Microwave Repair Guide
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
