Finalnotice
#1 Posted : Saturday, November 28, 2009 4:49:33 PM(UTC)
Finalnotice
Hi, I have a ge side by side fridge. Freezer side is cool and refridgerator side warm. Compressor and both fans working. Ice and frost on back wall of freezer. Any ideas of what I could check next?? Or what the problem is?
Qtip
#2 Posted : Saturday, November 28, 2009 7:38:36 PM(UTC)
Qtip
That is definitely a defrost problem. i dont have a way to see your exact model but there is generally 3 parts that will cause that problem.. the defrost heater(s) which is most likely. the defrost timer and then the defrost thermostat (most rare). the defrost heater will be located behind that wall with all the frost build up - you will need to unplug the fridge and let all that frost and ice melt thats behind that freezer wall. once its melted find the heater or heaters if theres two and look for any obvious damage to them (can test with a meter for continuity) and then post the results
#3 Posted : Sunday, November 29, 2009 2:35:48 AM(UTC)
You have a manual defrost timer in the fridg. section. Just look for an opening in the control panel and turn the defrost timer till the compressor stops running. If you now get defrost action, replace the defrost timer. If not, replace the defrost heater assembly AP2071464.
Guest (4)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Mabe MBC12GAZASS Not Cooling (Refrigerator & Freezer Repair)
by MKDrepair 2/5/2024 5:57:08 AM(UTC)
GE GSS23QSTA not cooling after power outage (Refrigerator & Freezer Repair)
by sfarid123 12/19/2023 7:39:47 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Whirlpool WRV986FDEM00 is not cooling (Refrigerator & Freezer Repair)
by Find a fix 9/23/2023 4:03:34 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
